RobUSMC Posted January 16, 2018 Share Posted January 16, 2018 I started a new plan with doing a plot plan. Its been a while since I needed to do one so I watched the video on the CA library. It showed how to change the dimension format to decimals so I could input the data as show on the engineers plat plan. However, when i was done with getting the plot plat completed, I changed the dimension format back to feet & inches from a decimal format and all the dimensions showing on the plan changed to this format. However, all dbx boxes I open for just about everything still show in a decimal format. Did I miss a default setting somewhere? Attached is the plan and a few screenshots showing the issue. Any help would be appreciated. Thanks Plan.zip Link to comment Share on other sites More sharing options...
justmejerry Posted January 16, 2018 Share Posted January 16, 2018 Rob, when I opened it this is what I got. No decimals. Have you tried opening since you sent file to see if it is corrected? 1 Link to comment Share on other sites More sharing options...
RobUSMC Posted January 16, 2018 Author Share Posted January 16, 2018 That did it. I guess if all else fails reboot. Thanks Link to comment Share on other sites More sharing options...
justmejerry Posted January 16, 2018 Share Posted January 16, 2018 Glad that it worked for you. Quite interesting how many things get corrected with a close of the plan sometimes. Link to comment Share on other sites More sharing options...
