Dimension Format Issue
RobUSMC
I started a new plan with doing a plot plan.  Its been a while since I needed to do one so I watched the video on the CA library.  It showed how to change the dimension format to decimals so I could input the data as show on the engineers plat plan.  However, when i was done with getting the plot plat completed, I changed the dimension format back to feet & inches from a decimal format and all the dimensions showing on the plan changed to this format. However, all dbx boxes I open for just about everything still show in a decimal format. Did I miss a default setting somewhere? Attached is the plan and a few screenshots showing the issue.  Any help would be appreciated.  Thanks
Plan.zip
