D11-Design
3D models - multiple materials issue
Hello!
I frequently download .skp files from 3D Warehouse and they work fine. They have multiple materials which can be adjusted separately (colour, texture, etc.).
However, most 3D models that I download from manufacturers' website have only 1 material in Chief, e.g. a sofa with a pillow on it, the pillow's material cannot be adjusted independently.
The issue occurs with almost anything that is not .skp: 3DS, DWG, etc. However, when these models are opened in their native environment (3DS in 3D Studio), they have of course different materials.
The strange thing is that sometimes 3DS and DWG formats work fine and they have different materials, which makes me think it must be some kind of a settings issue within these 3D files.
Has anyone found out the issue behind this?
Attached the .obj and .3DS formats of the same model downloaded from the manufacturer's website. The .obj format has 1 material, the 3DS format has 2 materials (strange as usually 3DS doesn't work).
ta_11bt_hp.obj
ta_11bt_hp.3ds
You can overcome this problem by exporting the object from chief in 3ds,
importing it into sketchup and then change materials there.  save and reimport
into chief.
    27501
    B1k3rm4n
    B1k3rm4n
  • Similar Content
    • By robdyck
      Is there still no material that will allow transparency in Vector View? I use a lot of glass for deck railings and its completely insane what needs to be done to make an exterior elevation drawing look decent. Currently, I need to build my railings without any glass, then build the glass manually, place on a separate layer so I can have it on in renderings, but off in elevation views (vector). Then, in elevation view, I need (choose) to manually draw p-lines with transparent fill to show the glass without blocking visibility of the structure beyond.
      I don't like fighting Chief's defaults and auto features, but I also want my drawings to have a certain appearance. Anyone have any thoughts or tips for transparent glass (not windows) in vector views?
    • By Luciano
      Hi everyone,
      Is it possible to create more then one new material at the time?
      I have in a folder filled with wood grain pictures (vertical & horizontal) and I would like to add them all to my library but doing it one by one will take forever... From what I see in the program, there doesn't seem to be a way yet. But I imagine or hope that someone found a way to do it.  I must not be the first user who wants to do that to save time. Any idea everyone?  Thank you.
    • By ginamk
      Hi,
      I'm having an issue with X9 - anytime I open an item and try to change the material type, I get a pop-up box that says "searching for files" and it appears to be searching through my file folders, but it's on a continuous loop searching the same folder endlessly so the search message isn't going away and I have to force stop the program. I've tried opening different files to see if it was just happening with a possibly corrupt file, but it's happening with several different files so I don't think thats it. I called the help line and they are not familiar with the problem. They said I should try my luck here.
      Anyone have this problem?
    • By DonSpring
      How do I take picure of a color or texture and use it in Room Planner as a custom material?
    • By BruceBoardman
      I'm in the Detroit area and looking for someone to take some architectural prints to CA to I can start doing interiors for our client. Don't have enough time to do it myself. Ideally, would like to see them completely by the 24th of June. Please feel free to PM me.
