Lee66cj5
foundation walls extending to top of 1st floor
I'm new to Chief Architect and have a problem with only certain foundation wallsls extending to the top of first floor framing in a slab house with 24" stem walls. the walls don't correspond to a specific room above, but in several rooms. I'm sure it's a setting somewhere, but I don't know where to look. the walls are shown in the picture below.I have had the program for about a week and I have to convert my standard house plans from AutoCAD.
Thanks,
Lee
way too many settings to guess at without a plan as Eric said .... especially from a small pic like that.....
close the plan in CA and drag and drop it into the light grey area in the reply window. If it is over 25mb , you will need to ZIP the plan to get below that limit , and/or delete some stuff from the Plan.
Thanks ,
Here is the plan for this house. I have isolated it to being an issue with the roof planes over these walls. If I erase the roof planes the foundation walls behave normally..
I appreciate your help.
Lee
Marwick.plan
You have a bunch of first floor walls marked as Knee Wall.
that appears to be it...... I am thinking the foundation wall picks up the attribute from the 1st floor since the Foundation is autobuilt.
Knee Walls
Knee Walls are a bit like Attic Walls in that they are not meant to generate to full ceiling height. Instead, they build upward until they encounter a roof plane. Unlike Attic Walls, however, Knee Walls are used in the interior of a structure, typically to separate unused areas from rooms on the upper floor of a story-and-a-half structure. See Room Types and Functions.
Chief Architect does not specify walls as Knee Walls automatically. If an interior wall is drawn in a location where the roof is lower than the ceiling height, you should specify it as a Knee Wall in the Wall Specification dialog. See Roof Panel.
For best results, Knee Walls should be drawn perpendicular to the pitch of the roof and should intersect with Full Gable Walls on each end.
Thanks for the info. I didn't realize I had done that. I changed all the exterior walls on the first floor to not be knee walls but it didn't change the problem. Here is the revised plan.
Marwick.plan
We may have spoken too soon , I was just playing some more with your original plan and it didn't fix it for me either......
might be a Wall Layer definition issue.... which can lead to an alignment issue...
If you take a cross section through the Owners Suite you can see there are two different wall types , not really as they both appear to be Boone 4" Brick,4" Exterior.
I'd have to look more when I have time.....
can you really only use a 3/8" air gap to brick where ever you are?
M
I believe the problem is the ceiling height in the foundation room. It should be 20".
What happens in a new plan when you build a simple, 1 room structure?
I suspected a wall definition issue too.
Change your foundation wall default to this.
Okay great , I do know Brick Walls by definition act differently than Framed walls but I hardly ever deal with Brick Walls these days...
Aligning Foundation Walls
The Foundation To This Line setting in the Wall Type Definitions dialog controls how a wall of a given type aligns with foundation walls directly below on Floor 0.
By default, Foundation To This Line is specified for the Main Layer of most wall types. An exception to this are brick wall types, which have Foundation To This Line specified for the exterior siding layer.
Thank you Solver and Kbird1! The problem was my wall definition for the foundation walls. When I moved the air gap and CMU to the main layer as Solver suggested then everything worked as expected.
Thanks again!
Lee
    28589
    555555
    555555
