Sign in to follow this
Red_Frog
Need a Desiger for a ICCF Home in AZ.
I'm  looking for a Designer or an Architect to design a 2562sq ft home in Seligman, AZ. 86337. Sitting on 40 acres, 3br. 3ba, office, Off the grid and ADA assessable.
ICCF blocks (Concrete Composite From) known as the gray block. Knowing AZ codes would a plus.
Want to use green products such as Better Than logs for the siding. Metal roofs, 18' x 16' kitchen, Bi-fold door, 10' wall and the living area 18', metal studs, joists, rafters.                                 Rustic Chic - open faux beams. front & Rear Decks.                     I have done my homework on all the products.
PM  Solver     (Eric)  he is in AZ
I just designed an ICF home for a client from AZ moving to AR. I'm a residential designer from CA if you're interested in working with someone out of state.
Daniel
209-534-7371
warrendesigninc.com
    27474
    Chieftan08
    Chieftan08
