copying wall type and layer sets
mikes616
One big advantage to the Library is that you can select a wall type and start drawing with it immediately.  Instead of having your "Default Wall Type" and then needing to change to the one you really want, you can just use the Library wall type.  You can draw over existing walls but that will eliminate any existing doors, windows, niches, etc.  OTOH, once a Library Wall has been drawn in the Plan, it will also be in the Plan Wall Types for use (change an existing wall to the new Wall Type).
