Exlude slab under carport
chiefnumber1
I'm working on a design now with a covered carport that will be next to the house but will be packed gravel instead of a slab.  Is there a way to exclude this area will doing the automatic foundation building or a better way to build the foundation in general.  The house foundation will be a monoslab.
In that case I think I would of just used 3 posts with footing and a beam , with a manual roof plane over it set at the correct Pitch.....  ie same way it is built ITRW assuming it has no foundation to speak of ?  .......................and find a better gravel texture than Chief's :)
