waltercruse
Craftsmen Style Gable End Brackets
Have you reviewed the brackets in the library?
Chief doesn't call them Brackets , or Knee Braces... they are in the Corbels Library under Millwork .... search RANCH  and you will find them....
Mick
You can use a truss -- adjust the parameters to get something you like.
Or, draw with poly solids. Take an elevation between the fascia and wall. Draw the various members -- change thickness and position as needed.
Block the pieces, move out from the wall.
    28587
    ChiefCarey
    ChiefCarey
