PLANsLLC123 Posted December 1, 2017 Share Posted December 1, 2017 Is there a way to add a fourth stringer to a set of stairs? Thank you, Tim using Chief X9 Link to comment Share on other sites More sharing options...
PLANsLLC123 Posted December 1, 2017 Author Share Posted December 1, 2017 Thank you for pointing me in the right direction. I did try a search initially, but search term(s) I used did not yield this result. Sounds like adding strings is a fairly common concern, according to the posts. Thanks again, Tim Link to comment Share on other sites More sharing options...
Mark3D Posted December 2, 2017 Share Posted December 2, 2017 post a screen shot for best suggestion maybe a poly line solid depending on your situation Link to comment Share on other sites More sharing options...
PLANsLLC123 Posted December 2, 2017 Author Share Posted December 2, 2017 Here is a shot of my plan, with the stairs in question highlighted. Any suggestions welcome. Thank you, Tim(A.4) FRAMING PLAN.pdf Link to comment Share on other sites More sharing options...
PLANsLLC123 Posted December 2, 2017 Author Share Posted December 2, 2017 Yes, exactly. Link to comment Share on other sites More sharing options...
PLANsLLC123 Posted December 2, 2017 Author Share Posted December 2, 2017 That automatically displayed with the stairs. So, doing as you suggest and adding a couple framing member polylines, then line selecting dashed, would work fine...I just need to 'white out' the single stringer. Link to comment Share on other sites More sharing options...
PLANsLLC123 Posted December 2, 2017 Author Share Posted December 2, 2017 Ahh...good to know. Thank you. That will come in handy. Link to comment Share on other sites More sharing options...
