MacChief
Add stairs to an already present U shape stair set
I've got a U shape set of stairs and want to add another run from the landing up - just opposite the second set. Can't figure how to do it?
Connecting 2 runs in an L, U is easy. Connecting 3 in a T configuration easy as well but can't figure how to add to a U.
Thanks for any help.
U-Stairs with indicated addition.pdf
Just draw the new stair starting at the landing.
add a copy of you plan for people to playn with , so they aren't guessing.....
you can use the Window's Snipping Tool ( in accessories) to take screen shots if needed , then no PDF's are needed.
good idea to fill in your signature too  since you are new , see mine for how to..
And please post images directly -- no need to make a PDF of an image.
Since I'm new to this forum I did not know anyone replied to my post until today. Thank you for your replies and forum tips. I'll try to be a little more clear.
I've got a U shape stair and I'm trying to add to the landing another run of stair up to the 2nd floor. When I attempt to do this the stairs are drawn on the first floor up instead of from the landing up. I'll send a file that somewhat replicates my situation. From the landing I'd like to make a L shape with 3 steps up, landing and then the rest of the way.
Stair Exercise.plan
I drew an L shaped stair, but a U shape works the same, then added the 2nd section off the landing.
Select the stair tool, find the mid point of the landing -- triangle will appear, and draw the new steps.
Here is a post I made that may help.
    27491
    alexvictory
    alexvictory
  • Similar Content
    • By Designer100
      Hey guys,
      I ariginally had cable rails and now I cannot get stairs to go back to noarmal stairs. Ballusters are not showing and I need to deleter the cable rails that are showing up in specs. Stairs has been move from another part of floor plans. Proably something simple.
      Can someone help?
      Richie_house._La_OPT._2_02_17.2020.zip
    • By DeckQuestions
      I'm trying to get stairs that look like this:
      They look like this right now:
      How can I achieve this?
      Thanks.
    • By Designer100
      I have designed a pergola and a deck. I cannot get the terrian to show right. It needs to be zero of level at back of deck by pool deck and slowly slope down to a bayou. it needs to be 36" to grade at edge of outer deck Then a stair going down to the end of stair which is around 5 fr lower that top of deck. I have not did much terrian and would appreciate your help. This is just a remodeling and adding a deck from the pool.
      Thank  you,
      Nerwell
      newell.cheatheam@gmail.com
      Pergola_.plan
      11X17.layout
    • By ChiefArchitect
      The living room offers a peek to the upstairs living area via the stairway. The glass panel railings and open concept design create a mechanism for the big windows on the first floor and the high shed windows on the 2nd floor to collaborate on the sharing of light and air between floors.
    • By MN_JohnH
      I am stuck on this one. I have a railing at the top of the stairs that I can't seem to get rid of. When I delete it the stair opening disappears. When i re-add the stair opening the railing across the top comes back.
      Stair rail problem.plan
