Sign in to follow this
sweetmelissa
Adding molding to a base cabinet
 As you can see in the attached pic, my adjustment for horizontal offset was uniformly made to the base and extends off the left end.  Is there a way to avoid this when adding molding to an end cabinet through the dialog box? By the way, I want to retain the toe kick as well as add bracket feet to it.
It looks to me like you added the molding to the toe kick area and then tried to move it out so it is flush with the cabinet box.
You will probably have better luck adding the molding to the cabinet box (raise it up some).  If you need to, you can adjust the bottom separation (face frame) so that you have something to attach the molding to and not conflict with your drawers.
Yes! Thank you!! When I adjust the molding from the top down instead of from the bottom up, it worked fine.  Haha, that's about all I didn't try! :)
    27470
    CAJNENT
    CAJNENT
