The company I work for builds a lot of post-framed buildings.  These buildings typically have a 4" or 6" concrete slab sub-floor.  If a project has a second-story, it is almost always wood I-joists with a 3/4" O.S.B. sub-floor.  That is if the second story is not a "Room-In-The-Attic".  This is how I have set up my template file to accomplish what I need it to do.
Step 1. - Floor/Ceiling Platform Defaults
If I was to set up my "Floor Structure" under the "Floor/Ceiling Platform Defaults" with a concrete sub-floor, I would get a concrete sub-floor everytime I added a second story.  I want Chief to default to wood I-joists with a 3/4" O.S.B. sub-floor.  This is why I set up my "Floor Structure" under the "Floor/Ceiling Platform Defaults" with wood I-joists and a 3/4" O.S.B. sub-floor.  Now if I add a second-story, it will default to wood I-joists with a 3/4" O.S.B. sub-floor.
Step 2. - Floor 1 Defaults "Current Floor Defaults" for Floor 1
Since I want a 4" concrete sub-floor for my first floor only, I set that up under the "Current Floor Defaults" for Floor 1.  I can have my "Floor Structure" for "Current Floor Defaults" for Floor 1 override my "Floor Structure" under the "Floor/Ceiling Platform Defaults".  That is if I make sure the check mark box for "Floor Structure" under the "Current Floor Defaults" for Floor 1 is unchecked.  That means it is going to deviate from the "Floor Structure" under the "Floor/Ceiling Platform Defaults".
PLEASE NOTE!
My "Floor Structure" for all rooms on the first floor will only match the "Floor Structure" under the "Current Floor Defaults" for Floor 1, if all room types are set to use the defaults.
Step 3. - Save the Template.
I have saved my file as a template so I can reuse this floor platform set-up.   I did not bother adding a second story or level in my template file.  I can always add a second story later on when I start a new plan file based on my saved template.
Step 4. -  Add New Floor / Floor 2 Defaults "Current Floor Defaults" for Floor 2
If I need a second story I add one.by clicking on the appropriate icon.  This will take me into my "Current Floor Defaults" for Floor 2.   Since I have already set my "Floor Structure" under the "Floor/Ceiling Platform Defaults" with wood I-joists and a 3/4" O.S.B. sub-floor in my template file, I just make sure the check mark boxes are check marked to use the defaults.
5a114d9c8ed9f_CA-Floor04.thumb.jpg.7b555d74f4473f6094b8a57bc8a42648.jpg     5a11502fc5bf6_CA-Floor05.thumb.jpg.66201af3fee9050a6354e9bd109bf873.jpg
With floor and ceiling platforms, you have a hierarchy of settings and you must pay attention to what is check-marked to use the defaults.   You can specify floor and ceiling platform information in about four locations...
1. "Floor/Ceiling Platform Defaults"
2. "Current Floor Defaults"
     Please Note : Each floor of your plan file has "Current Floor Defaults".
3. "Room Type Defaults"
     Please Note : If a room type definition is not check-marked to use the defaults, it will override the "Current Floor Defaults" and "Floor/Ceiling Platform Defaults"
4. "Currently Selected Room"
     Please Note : When changing platform settings for let's say a room that has a room type of "Bath", clicking on the room labeled "Bath" with only change platform settings for that one instance of the room with a room type of "Bath".  To change platform settings for all rooms on all floors selected to have a room type of "Bath", we have to go into the "Room Type Defaults" and change the platform settings for "Bath" there.
too many default places, Chief please narrow it down to one place. I may have missed it ,but there are also places in the framing DBX. just too many default places.
    27478
    Oilersfan20
    Oilersfan20
  • Similar Content
    • By CHROMATICGA17
      Need to set default pricing for product/materials to use as default template. This way generating my materials list will be quicker.  I do not want to enter vendor specific pricing.  I want to enter labor pricing for specific materials.  I want this to default to my setting per item/sf/etc. each time i choose that template to start a plan.
      I hope this question makes sense.  Please help.
    • By YoderW
      Hello!
      I'm working on a huge plan right now, and it's starting to run really sluggishly so I decided to take some time out to troubleshoot and clean up the file a bit. I've done a few suggested things (purge unused materials and CAD symbols, for example), and moved on to my layers. When I started the file, I imported all individual layers of the CAD file so I could work on the plan bit by bit, but it also resulted in a lot of unnecessary data being added to the scene. I'm trying to go through and delete all the layers I don't need or have finished with, but most of them won't let me. Some will claim there's still something on them despite nothing showing up when I hit Control+A, and others will switch to "Used in defaults," after I deleted everything on them. But I don't know what that means, and I can't figure out where in the defaults they're being used so I can turn it off.
      The layers that claim they aren't empty when they should be are bugging me, too. Control+A, zooming out and dragging a box over the scene never select anything for me to delete, but they still say "in use." I may be able to provide a back-up if necessary, though I'm not sure my company will allow it and, again, it's a very large plan. Can anyone help?
    • By NobleRenovation
      Good evening, I was tweaking my defaults today and somehow I must have turned on an extra layer for temporary dimensions?
      How do I disable temporary dimensions when I am only selecting a wall?  For instance, I click on a wall ( I already have a dimension on the plan), and I get like a doubled mirrored effect of temp dimensions, very busy looking when this happens.
      Can you please assist how to disable ?  I do like the temp dimension when I am drawing a new wall...to show the length... so I want to keep this on...
      Many thanks
      Steve
    • By BruceBoardman
      Good day all,
      I am using v10 on a MAC. I'm an intermediate user and don't use Ray Trace a TON. 'Doing my first set of traces is v10 and all my setting seem to be off. My ceilings are glowing, the lighting doesn't seem right. Blah blah blah. I have imported defaults from an older file that had my best settings.  I have a presentation this afternoon to sell this project anyone able to open this file and see what my deal is?? Oh and I can't figure out where to change my backdrop, either. Did it move?
      What am I missing? I'm sure it's simple.
      GAT_glowing_effect.plan.zip
    • By KellyD
      Hello,
      I am a new user...I have consulted my book, watched video uploads, but cannot find the answer to my question.....
      When I open "Saved Dimension Defaults" the only option is "NKBA Dimension Defaults".  I do not have any of the others, such as "1/4" Scale Dimension Defaults" etc.  Also don't see how I can add it other that copy and format it myself.  Does anyone know if I can import these other defaults options?
      Thanks so much in advance!!
      Kelly
