finding simpson strong tie connections in the library
crosscutter55
were they sketchup files you imported into Pro?  then export your User library from Pro and import into Chief
or just the appropriate library from Pro if that is all you want to bring over....
CA will migrate them to new versions but I don't think it does that when you upgrade from Pro so you will need to do yourself with import/export...
