Designer1 Posted November 5, 2017 Share Posted November 5, 2017 Does anyone know when using exterior railings for covered porches if you select "post to beam" if the beam as default is a standard sizing? For some reason when I look at it, it appears too small. If this isnt standard sizing does anyone know where we go on the railing dbx to change this? Thanks, Chad Link to comment Share on other sites More sharing options...
glennw Posted November 5, 2017 Share Posted November 5, 2017 You can also change it in the Railing Defaults to save editing it after you draw the rail. Link to comment Share on other sites More sharing options...
Designer1 Posted November 6, 2017 Author Share Posted November 6, 2017 Thanks Eric and Glenn! Link to comment Share on other sites More sharing options...
