Sign in to follow this
ajrare
Exterior cable rail
What am I doing incorrectly?    Want  a cable rail.   Cables appear to run perpendicular to what is needed.
The attached third pic is similar to end result needed.
You need to change the rail style to panels, then under the newels and balusters tab, change the panel type to "cable".
    27825
    ChiefDallas
    ChiefDallas
  • Similar Content
    • By mrscott
      I created a curved set of stairs (correctly or not) and when they attached to Railing Wall, one portion is missing. There basically three staircases. One from the ground to the landing where it splits off into two up around the fireplace and on up to the balcony railing. The plan is attached someone would mind taking a look. I also don't like the way the interior stair at working either. They cut into the room behind the staircase and just aren't cooperating. It will make sense when you see them.
      Thanks for your feedback,
      Venue 1.zip
