builtright3 Posted November 2, 2017 Share Posted November 2, 2017 I need this deck to go over the top of this retaining wall (cantilever over it about 12 inches).Its not allowing me to do it. Any help would be appreciated. Share Plan.plan Link to comment Share on other sites More sharing options...
DavidJames Posted November 2, 2017 Share Posted November 2, 2017 Like this? Just move the railing walls out to where you want them to be. You'll just need to then turn off autoframe and adjust the pads and beams accordingly. Link to comment Share on other sites More sharing options...
builtright3 Posted November 2, 2017 Author Share Posted November 2, 2017 3 minutes ago, solver said: Just dragging the walls did not seem to work for me as the retaining wall below wanted to move with them. Using temporary dimensions did work. Yes this is the same issue im have. What magic trick do you use David? Link to comment Share on other sites More sharing options...
DavidJames Posted November 2, 2017 Share Posted November 2, 2017 3 minutes ago, solver said: Just dragging the walls did not seem to work for me as the retaining wall below wanted to move with them. Using temporary dimensions did work. Sorry, I forgot to mention that I moved the railings by holding CTRL and then used the "connect walls" command to rejoin them. Link to comment Share on other sites More sharing options...
builtright3 Posted November 2, 2017 Author Share Posted November 2, 2017 I have a long way to go yet but you solved that problem for me. Thank you David! Link to comment Share on other sites More sharing options...
DavidJames Posted November 2, 2017 Share Posted November 2, 2017 No worries at all Link to comment Share on other sites More sharing options...
