Landing rail color
JeanTurcotte
Go to solution Solved by JeanTurcotte,
There are som cases that I've encountered where the materials tab doesn't list a particular element to modify.  Sometimes this is because the Plan was migrated from a prior version that didn't include that element.  In other cases it's something that CA simply missed in the software.
IAE, I find that careful use of the Material Painter can take care of the problem.  But be careful and make sure you uncheck Blend Colors with Materials so that you don't get a mess.
  • 2 weeks later...
