ChiefuserLarkin Posted October 25, 2017 Share Posted October 25, 2017 Anyone run into this where the doors are shown hidden by the landing? Thanks! Link to comment Share on other sites More sharing options...
DavidJames Posted October 25, 2017 Share Posted October 25, 2017 This is happening because your stairs and your landing have a white fill. Double-click on your landing, select the fill tab, change it to "none". Link to comment Share on other sites More sharing options...
ChiefuserLarkin Posted October 25, 2017 Author Share Posted October 25, 2017 Thank you!!!!! Link to comment Share on other sites More sharing options...
Dermot Posted October 25, 2017 Share Posted October 25, 2017 If you remove the fill on your landing, you will then see everything under it. Maybe this is ok but maybe it's not. Another solution is to change the draw order. Move the door up so that it is drawn after the landing. Landings are drawn with stairs in group 22 while doors are drawn with other openings in group 25. Move your door up to group 21 (or any other group with a lower number) and it will draw on top of your landing. 1 Link to comment Share on other sites More sharing options...
