Rossalaki
Kitchen Cabinet with multiple material
How can I apply multiple materials to the face of a cabinet? For example, how can I have a white drawer and a black door in the same cabinet?
I have the same issue with cabinet box. For example, I cannot have a box with a white bottom and black sides.
Thank you!
That's exactly what I want to do. But when I apply a material to a drawer, the door gets the same color as well. I use the C mode.
In my case, it was all slab door. I guess I can change it to a slab from the library. thanks!
Is there a trick to paint the bottom of a cabinet? For example, here I want to have bottom and toe kick the same color, but keep the rest white.
By bottom do you mean the toe height on the sides, the floor of the cabinet, or just the front of the bottom rail?
I mean the floor of the cabinet.
I just want the floor to be a different color than the two sides.
You can achieve the material difference that you are after by deleting the bottom member from the cabinet, and adding a shelf, with zero as its separation height. The shelf material can then be set to whatever you want.
    27478
    Oilersfan20
    Oilersfan20
