buzzsaw204 Posted September 11, 2017 Share Posted September 11, 2017 hi, where or what Text Style is use for the Temporary Dim. lines. i would like to make it big, as i sometime use it when i manually stretch the poly line. thank you. Link to comment Share on other sites More sharing options...
BrownTiger Posted September 11, 2017 Share Posted September 11, 2017 Edit>Default Settings > Dimension > Dimensions > Basically it is your active default dimensions for whatever scale e.g: 1/4" Scale Dimensions Defaults Link to comment Share on other sites More sharing options...
