Sign in to follow this
pjs-tex
Design Services
I have a property near downtown Austin, Texas, that I would like to develop. I am not yet a Chief Architect user, but looking to purchase the program. My first step so far is to get a full survey of property including Boundary Survey, Tree Survey,Topo Survey and Survey of ground utilities. I am told by survey company, that I can get a Auto-Cad 2000 format which I believe would be a .dwg format, that I believe can be imported into Chief architect.
I have read some of the posts in the forums, and thus far I am seeing a few new users starting their projects, and basically floundering due to inexperience in using the program. I really want to avoid making mistakes in the early stages, especially in the importing of the survey file. I also need to dance around a few trees, so I also need help establishing a building footprint . There is also the City of Austin rules, relating to setbacks etc, which are relatively straight forward  IE McMansion rules and allowable square footage  for size of lot requirements.
So having said the above, I am looking for an experienced designer, that can help with design, as well as with construction drawings and materials list.
Let me know your comments.
Kind regards
paul
I can help you!
I am a creative designer with unique experience and perspective from my collection of work as a designer and builder.  I have degrees in structural engineering (BS Rice University) and architectural engineering (MS University of Texas at Austin) and have planned, designed and developed various types of projects over my 30-year career.
I use Chief Architect Premier X9 (SSA member) and have used Chief Architect since Version 9. I use GoToMeeting to work with customers and am technologically versed in all types of software that help me in my design business including, for example, creating flash and 3D pdf files.
Regards,
Charles
I have designed a number of project remotely for designers, builders, and designer/builders. several of which have been in Texas. Please contact me if interested.
Hi, Have seen your attachment and understand your requirement. It could nicely be done in chief architect. Currently I am using X9. Please knock me if you are interested. Thanks.
    27370
    designsbyalex
    designsbyalex
  • Similar Content
    • By LeeDrafter
      Hi All,
      I am working on townhomes that are exactly the same on both sides. I need the room dimension labels to be the same on my "advertising" plans or people will get confused and wonder why they are different. The actual dimensions are exactly the same, but I don't want to show people all the dimension lines for advertising. As you can see in the attached, both living rooms are actually 13' 10-1/2" X 16' 9-1/2". The room labels are rounding to 16'8" on one side and 16'-9" on the other side. I don't care if it rounds up or down, but I do need it to be the same on both sides. Does anybody know how to fix this? I am working in X5.
      Thanks!
      LOTS 112&113 BIGFORK LANDING.zip
    • By LeeDrafter
      Hi All,
      I am working on a 4 plex. When I edit -> all floors and then reflect about the center line to create the other side of the 4 plex, a lot of the dimensions get messed up. Some of them are moved to the other side and deleted from the original side, and some are stretched. How can I avoid this or do it correctly? See the picture. Thanks!!
