saintbrendan
Architectural Survey/Drafting needed in Philly
Hello,
I'm looking for a someone to do a field survey of an existing 3 story residential property (center city Philadelphia).  I'm guessing I could have it sent to me as a dfx file, but would rather they created the layout in Home Designer (Suite) to save me some of the work.  Anyone know anyone in Philadelphia that offers this service?
Thanks, Brendan
Any land surveyor should be able to do the (Field)  Survey for you and it is more than likely it would come in DFX format (and PDF) , however HDS can not import DFX files AFAIK unless that has changed recently?  AFAIK only HD Pro of the DIY line can import .DFX files
You can rent Pro now (2018 version)  for $49 a month if you need it.
https://www.homedesignersoftware.com/software-rental/
Might be best to call CS tomorrow and ask a few questions, phone numbers are here
https://www.homedesignersoftware.com/support/#contact
I am interested in seeing how we might be able to work together over the internet
and with me making a visit to Philly to do the measuring and initial drawings for the asbuilt set of plans.
I reside here in SW Florida, my business name is Accurate As-builts & Design, I would like to speak to you
if you will please contact me directly?
I have a lot of engineering technician experience and background, references, resume all included.
Have worked on Chief Architect now for about 4-5 years and use CA X9 Pro, which BTW saves down to Home Designer
software.
My contact info is as follows.
Douglas Burgmann
(970)987-4476 cell
email: douglasburgmann@gmail.com
web:   http://www.dcbcaddesigns.com
DCB Designs_Resume-(12-12-16) - FL.docx
City Reference Letter Burgmann.pdf
NABCEP PV Solar Certification0001.pdf
Pattillo Recomendation Letter0001.pdf
    27478
    Oilersfan20
    Oilersfan20
  • Similar Content
    • By brmurphy
      I have Home Designer Suite 2019 and would like to find someone to draw my entire house in the software. I would mail a copy of the original paper house plans and then would like the house professionally drawn in the software so that I can go in and edit and make changes over time.
    • By DCB123
      I work in Chief Architect X10 drafting support at an reasonable hourly rate, or by the job at a sq ftg price for bigger jobs.
      I have well over (10) years of Chief and architectural design experience.
      Samples of my work are on my website www.dcbcaddesigns.com,
      or on Facebook at dcb1234.
      Please feel free to IM me, or better yet, give me a call, to see how we can
      illuminate your next project for you. I am on Eastern Time zone here in SW Florida.
      I look forward to hearing from you!
      Thx,
      Douglas Burgmann
      (970)987-4476 cell
      web: www.dcbcaddesigns.com
      FB: dcb1234
       DCB Designs_Resume-(08-10-17) - FL.docxCity Reference Letter Burgmann.pdfPattillo Recomendation Letter0001.pdfDCB Designs_Resume-(12-12-16) - FL.docx
    • By RandyWeber
      Hi,
      I would like to speak with someone who would be interested in teaching me the Home Designer software in a more in Depth way. I'm an IT consultant currently in transition to renovating homes. There are several items that I am having trouble with that are probably very easy for someone to show or teach me.
      Thank you in Advance,
      Randy
    • By C_Parrilla
      All,
      FYI - I'm new to Chief Architect Home Designer 2016 and Room Planner iPad app.
      I created a simple plan (square room with a few wall and base cabinets) on room planner and saved it to the cloud (Green Cloud icon). I closed the app and reopened it to make sure the changes were saved. Then I go over to Home designer 2016 Architectural (Trial) and  -> create a new design -> and go to import and then "Import Room Planner File". I put in my credentials and see the designs I've. The thumbnail that is displayed for all my plans do show the rooms with the cabinets as it does in the iPad app. The issue is that when i select and import the file, I only see the outline of the room but not cabinets. I did a 3D perspective overview but I only see the walls. No cabinets at all. Am I doing something wrong or is this how the import feature is designed to work? Does it matter i'm using the Trial version of Home Designer? I even went ahead and saved a sample plan that was full of cabinets and rooms but same result. Attached are just a few images of what i see. Any other details needed just let me know.
      Thanks in advance for the help everyone.
