ronald Posted June 16, 2017 Author Share Posted June 16, 2017 18 hours ago, Dermot said: Ronald, I believe your particular problem is related to your video card. Unfortunately, it looks like updating the drivers does not solve this particular problem. One possible solution would be to adjust your Render Preferences and turn your Hardware Edge Smoothing to either High or None. We were only able to repro this problem on one machine with this setting on Low. Dermot! That was the solution! Thank you! Thank you! I will inform Tech Supp so they can effectively advise others in the future. Best Regards, Ron Link to comment Share on other sites More sharing options...
Kiwideziner Posted June 21, 2017 Share Posted June 21, 2017 reported this problem a while ago and tech support blamed hardware. I have not seen it lately but I think i have just turned the labels off in elevations, which was what i had to do when i found the problem. dont think i have actually turned them back on. will have to check. Link to comment Share on other sites More sharing options...
ChiefLBC Posted February 19, 2018 Share Posted February 19, 2018 Tried all of these and no luck, the interior door labels show through the walls only in layout file but not in my plan file. Link to comment Share on other sites More sharing options...
