NectarDesign
Window Schedules
Is there a way to stop CA from re-labeling window label numbers when they are adjusted?? I have sent my window schedule off the the supplier for quoting, I have a few adjustments on the sizes from the supplier, but when I make those adjustments, CA re-numbers the windows... which now doesn't coordinate with the suppliers schedule. Really frustrating as I can't seem to find a way to stop it. Even if you use the move up or down schedule tab, it then re-numbers all the other windows. Maybe there is a simple solution?
If you have a copy of the one you sent to the supplier you can select the schedule and drag the window numbers to the position you had them in the one you sent him then resend it to him
    27469
    THDesign
    THDesign
