Sign in to follow this
Renerabbitt
Gold Cross Mirror Cabinet Doors
    28141
    kepine
    kepine
  • Similar Content
    • By stevenyhof
      I have downloaded the three garage door catalogs from the Library, and non of them have a standard wide paneled garage door. They also do not have a wide paneled 8' high door (5 panels high)
      What they have is 5 panel high flush doors - so this can be stretched - cool
      But there are no standard paneled, wide (16' and 18') 4 or 5 high garage doors.
      Does someone have access to such doors?
      The long panel door comes in both 4 panel wide and 2 panel wide - very good.
      The door with the 4 panels across come should also come with 8 panels for wider doors.
      Am I missing it somewhere? It's like the most common door used from Menards and Lowes. Starter doors.
      Thank you
    • By elijahkay
      Is there a currently available way to apply a separate color and line type to the swing of the Swinging Door object?
    • By kylejmarsh
      Here's the door I need to specify, an Andersen A-Series with three panels:
      Here are the options that chief gives me for a hinged patio door:
      Should I just write a note on the drawing that says 'my software can't make a door like that...'  I'm embarrassed to admit this to Kevin, a fellow local designer who is thinking of moving to CA or a similar program, because I always talk up how great Chief is but then there's stuff like this.
      What do experienced Cheefers do?
    • By SMC2992
      Hi friends
      I want to draw a door to a strong room which has 2 single shutters, one opening inside of the room and second out side to the room. the wall is 12"thick.
      How i can achieve this?
      thanks
      Salahuddin
    • By Designer100
      Does anyone know ho fix issues I have on this commercial remodeling addition?
      1) Windows and bar cabinets are not against the wall!
      2) wall is not showing on full camera looking back toward where it attaches to the existing building. Wall existing is brick on inside, unless I decide to cover it with gypsum bd!
      3) I have a 10 ft. plate with 9 ft dropped ceiling 2 ft x 4 ft acoustic tile in new addition.
      x12
      Newell Cheatham
