ChiefUserTom7 Posted June 5, 2017 Share Posted June 5, 2017 Can anyone suggest how to place brick supports under a raised front porch? I am using HomeDesigner Pro. I have the porch attached with the roof covering the porch (gullwing roof), but I haven't been able to figure out how to add the square brick supports. The supports match the old brick on the house and slope down from left to right (the terrain slopes in this direction when facing the house, so that the supports are of different lengths). Thanks, Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted June 5, 2017 Author Share Posted June 5, 2017 Thanks, I'll check on Home Talk. I'm using HomeDesigner Pro 2018. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 5, 2017 Share Posted June 5, 2017 You can make your newels 16" sq. and a brick material, and use post to beam, but not sure what your actual conditions are and capabilities your program has, or just use p-solids for your newels. Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted June 5, 2017 Author Share Posted June 5, 2017 Using HomeDesigner Pro 2018. Thanks. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 5, 2017 Share Posted June 5, 2017 I saw that , just suggesting , if you have the capabilities, that's how I would do it in premier. There are lots of other ways also. Link to comment Share on other sites More sharing options...
