nickiascone Posted June 4, 2017 Share Posted June 4, 2017 On an exterior wall , the dimension tool will do interior surface wall to exterior surface, but measures to the brick, how do I get it to measure interior surface to interior surface on an exterior wall?? I want Interior surface dimensions only. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 4, 2017 Share Posted June 4, 2017 Zoom in, select the dimension string, then while selected left-click-drag the dimension point to the layer you desire to measure to, easy-peasy! Works in any version of Chief or Home Designer software. DJP Link to comment Share on other sites More sharing options...
nickiascone Posted June 5, 2017 Author Share Posted June 5, 2017 Thanks Dave, But what I am looking for is...to be able to click on a wall and it give me the distance between it and the opposing wall just by clicking, but want interior surface to surface dimension. Would appreciate if you could help me with this!!! Link to comment Share on other sites More sharing options...
nickiascone Posted June 5, 2017 Author Share Posted June 5, 2017 I figured it out..You go into Edit, Dimension Default, Wall Dimension , Layer and both wall surface...done!! I appreciate your time! Link to comment Share on other sites More sharing options...
