DBearss Posted June 1, 2017 Share Posted June 1, 2017 How? I get one section that shows insulation - incorrectly - then others with nothing. Something simple and obvious I hope? Link to comment Share on other sites More sharing options...
glennw Posted June 1, 2017 Share Posted June 1, 2017 I assume that you are using Auto Detail to generate the insulation hatching. Auto Detail only works on the currently active section - it is just a cad that overlays the section. You need to explain in more detail regarding the incorrect insulation. Link to comment Share on other sites More sharing options...
DBearss Posted June 1, 2017 Author Share Posted June 1, 2017 Well there you go. This job was shelved for a bit and I jump back and forth to CA and ArchiCAD so totally forgot what I did. Auto detail it is. Thanks for the reminder. Also the insulation corrected itself. Thanks. Link to comment Share on other sites More sharing options...
