HumbleChief Posted May 23, 2017 Share Posted May 23, 2017 Not sure what's happening here but I can't delete certain items and now I can't select a hole in a slab in order to delete it. If I insert a new hole I can select and delete it but not the other hole. I can replace the slab easily enough but am just wondering what I'm missing? Anyone else experiencing this? Attached plan. hole_in_slab.plan Link to comment Share on other sites More sharing options...
HumbleChief Posted May 23, 2017 Author Share Posted May 23, 2017 6 minutes ago, solver said: If you convert the slab polyline to a plain polyline, then back to a slab, you can select the slab hole. Thanks Eric, but what happened? And why should one have to do that? I can always just replace the slab which is essentially what you suggesting but why? There's a couple of buggy things I've encountered with this new release but that doesn't lessen my appreciation for your help and time. thanks again. Link to comment Share on other sites More sharing options...
