DaniBurger Posted May 23, 2017 Share Posted May 23, 2017 Hello, I've upgraded to X9 and can't seem to figure out how to make one cabinet door (inset) with three panels. Any ideas? Thanks, Danielle Link to comment Share on other sites More sharing options...
Chris_Kelly Posted May 23, 2017 Share Posted May 23, 2017 If you can't find anything suitable in the library, what I would do is build the door you're looking for with polyline solids, export it as a 3ds, then import it as a 3d symbol and add it into your user library. https://www.chiefarchitect.com/videos/watch/5305/importing-symbols.html?playlist=108 Link to comment Share on other sites More sharing options...
MarkMc Posted May 23, 2017 Share Posted May 23, 2017 Is this what you mean? These are made using a cabinet- panels are "side panel inset". I have a bunch of door symbols that are panels without frames that I use as wainscott or to make door symbols. I've posted "kit" plans over in symbols in the past. Also instructions for doing it and Michael (Alaskan Son) did a vid on it in tips I think. 1 Link to comment Share on other sites More sharing options...
DaniBurger Posted May 23, 2017 Author Share Posted May 23, 2017 yes! The one on the right. MarkMc. I'm spending an hour trying to create it with polylines. How do I get to convert to a symbol? Link to comment Share on other sites More sharing options...
DaniBurger Posted May 23, 2017 Author Share Posted May 23, 2017 HI Solver! Done! Thanks!!! Link to comment Share on other sites More sharing options...
MarkMc Posted May 23, 2017 Share Posted May 23, 2017 With a multi-panel door you have to watch stretch zones and planes. Normally cabinet door symbols work best with stretch zones as opposed to planes. Problem is you can't have multiple zones, only multiple planes. Make the door symbol close (or better yet) exactly the size you need if at all possible. Using cabinets to build the symbol allows making new sized symbols quickly using the same plan. Attached shows zones on a single door cabinet where the center rail is set to align with base cabinets. The double door rail is also set that way but in this case the stiles resized to be slightly off once the door was configured to the correct size. Link to comment Share on other sites More sharing options...
