JECORMIER Posted May 13, 2017 Share Posted May 13, 2017 Hey All - I've got this two story walk-out basement plan I am working on. On the front two corners of both levels where the covered porches / entry hit the main wall corners I am getting some wonky issues that will not allow them to come together cleanly. You will see once you click on the corner walls, (REVISION CLOUDS) multiple 1 and 2' long walls and room definitions (porch/entry) that shouldn't highlight into the interior rooms. I've tried deleting all the little sections of wall and pulling from the longest walls but they always revert back to wall sections. I don't know if there is a foundation issue or a wall issue or a room perimeter issue. The elevations also show a 4" material change that is also unchangeable. By not connecting the room perimeter on the right side upper level the decking for the covered porch does not form up to the wall. I intentionally left this so you can form finish the move and see what happens. I know it's user error but I've gone down this rabbit hole so far I don't know my way back. Ha. If you have some idea on how to fix it or if it's a quick fix then fix it but please let me know how you did it so I can learn. Either way any help would be great. I have included the plan.... Thank you in advance! Justin TVB_OFFICE.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 13, 2017 Share Posted May 13, 2017 All of your floor zero walls are out of alignment with the walls above. They were also mismarked as being "Terrain Walls" (which they are not). You really need to carefully read your "Reference Manual" in various places so you no longer guess what to do but you know what to do. DJP Link to comment Share on other sites More sharing options...
JECORMIER Posted May 13, 2017 Author Share Posted May 13, 2017 Thank you for your insight. Link to comment Share on other sites More sharing options...
JECORMIER Posted May 13, 2017 Author Share Posted May 13, 2017 Yes, I saw that too but didn't know what to do with it. Great, thank you solver! Link to comment Share on other sites More sharing options...
JECORMIER Posted May 13, 2017 Author Share Posted May 13, 2017 The corner issue is solved NICE! THANK YOU!!! but now the three concrete foundation walls do not show in sections or elevations but do show in floor plan. What am I missing here? New plan attached... TVB_OFFICE.plan Link to comment Share on other sites More sharing options...
JECORMIER Posted May 13, 2017 Author Share Posted May 13, 2017 Ok. closed the plan down again and now it seems the only issue is the right side foundation wall is the only one acting up. Cool. almost there... Link to comment Share on other sites More sharing options...
JECORMIER Posted May 14, 2017 Author Share Posted May 14, 2017 I agree Solver. Next time I will build it with a separate foundation. Thank you- j Link to comment Share on other sites More sharing options...
