Summers Posted May 12, 2017 Share Posted May 12, 2017 I'm responding to my first set of plan check comments using Chief. How do I mark revisions? The "Revision Cloud" is easy to use, but is there an automatic way to mark the cloud with a "delta" and a number inside the delta, or do I need to create the delta and number, save it as a Library detail, then place it manually on each cloud? Thanks, LS Link to comment Share on other sites More sharing options...
johnny Posted May 12, 2017 Share Posted May 12, 2017 I have to agree with you - its very odd Chief doesn't have labels for revision clouds (as most polys do) - at least then you could simply place a triangle over the label. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted May 12, 2017 Share Posted May 12, 2017 Happily, Chief DOES provide this function -- somewhat. You can add a triangular callout marker in Layout and insert a %revision.label% macro, and the revision number will appear from the Page Revisions table. (go to "Edit Page Information" to get to this.) You do have to add the callout manually, but it's not bad, since you can copy it. Link to comment Share on other sites More sharing options...
johnny Posted May 12, 2017 Share Posted May 12, 2017 4 minutes ago, Richard_Morrison said: Happily, Chief DOES provide this function. You can add a triangular callout marker in Layout and insert a %revision.label% macro, and the revision number will appear from the Page Revisions table. (go to "Edit Page Information" to get to this.) You do have to add the callout manually, but it's not bad, since you can copy it. I was trying to follow your instruction and am almost there. How though do you differentiated the numbering for different revisions? When I place a 2nd, 3rd, etc, etc revision note all the callouts change to that number. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted May 12, 2017 Share Posted May 12, 2017 It only picks up the last revision number, which can be either good or bad, depending on your view. Otherwise, you can just add the number directly. In general, I probably wouldn't want multiple versions of revision deltas, but some people do. Link to comment Share on other sites More sharing options...
Summers Posted May 12, 2017 Author Share Posted May 12, 2017 Thanks, Richard. Like you, I generally want to see only the latest revisions, however, I usually don't have more than one Rev (even in the Bay Area). When you make revisions to larger-scale details do you prefer to add the cloud and delta inside the detail, or on the page? This raises the issue of annotation sizing, which I've struggled with in Chief. Regards, LS Link to comment Share on other sites More sharing options...
Richard_Morrison Posted May 12, 2017 Share Posted May 12, 2017 In general, I usually like to see the revision clouds and deltas only on the layout page, because it's easier to manage layers. You only have the one layer on the layout page, vs. needing to pay attention to layers if you have them in the plan, say, multiple clouds on a framing plan and electrical plan and floor plan. You also have consistent sizing this way. (Uncheck automatic sizing, of course, for the callouts.) Link to comment Share on other sites More sharing options...
