country Posted May 3, 2017 Share Posted May 3, 2017 (edited) I would like my grade beam to be tied in slightly above the corner of the foundation to accommodate even dimensions for the formwork on all the front sections. I cannot seem to get a clean join for the construction drawings. Do I have to do this with a CAD overlay like I have attached or is it possible with wall joins? I have given up trying:-( Plan and Image should be attached. This is in X9. I see I have to update my profile. Grade Beam.zip Edited May 3, 2017 by country Link to comment Share on other sites More sharing options...
Kenoeightspot Posted May 3, 2017 Share Posted May 3, 2017 See attached plan. ANGLED FOUNDATION WALL.zip 1 Link to comment Share on other sites More sharing options...
country Posted May 3, 2017 Author Share Posted May 3, 2017 Thank you. How did you get it to go in square? I tried for most of an hour and it kept trying to angle or mess up the basement corner. Link to comment Share on other sites More sharing options...
Kenoeightspot Posted May 3, 2017 Share Posted May 3, 2017 I pulled the garage wall back then removed a small wall as shown on below then reattached wall. Link to comment Share on other sites More sharing options...
country Posted May 3, 2017 Author Share Posted May 3, 2017 Once again thank you. I thought that's what I did in my very first attempt at joining them (I think the extra wall is there from one of the other attempts) but I will certainly give it another try. Link to comment Share on other sites More sharing options...
