Asymmetrical interior double door
contractcad
Is there an easy way to create a Asymmetrical interior double door? I have a doorway that the max width I can get is only 5 feet and I need to create a door where one door has to meet the minimum ada requirement of 34" clear.  It requires a door where one is 36" with a door latch and closer with the other being 24" pin locked with a manual swing and lock open.  It's for an entrance into a banquet room.  I can easily place a 5 foot double door but I'm not seeing where I can modify the doors to different widths within the same frame.  My only out I can think of typing in a description of my intent but using a standard symmetrical double door.
