Designer100 Posted March 26, 2017 Share Posted March 26, 2017 finished floor 5'6" above grade, garage is regular slab (with stair going up to laundry room. any help verifying above and with stair -landing - stair to entry porch. Also I cannot get kitchen island to close up.I have tried break tool and still cannot get it to work. Any help would be appreciated. Thanks McVaugh.Jim_Custom.plan.7z Link to comment Share on other sites More sharing options...
Mark3D Posted March 26, 2017 Share Posted March 26, 2017 adjust your stairs manually by un ticking auto height and with benchtops island try custom counter tops not shelves Link to comment Share on other sites More sharing options...
Designer100 Posted March 27, 2017 Author Share Posted March 27, 2017 Thanks, I will try it. Link to comment Share on other sites More sharing options...
Designer100 Posted March 27, 2017 Author Share Posted March 27, 2017 1) I still cannot get the entry stair and garage stair to work out. see sketch and then my floor plan. 2) House finish floor is 66" off grade (surpose to be). Garage is 12" off grade. I cannot figure it out. Any help would be appreciated. Thanks, Newell 713.385.3622 17013-Front elevation 3-14-17.pdf 17013-First floor 3-14-17.pdf McVaugh.Jim Custom.plan.zip Link to comment Share on other sites More sharing options...
Mark3D Posted March 27, 2017 Share Posted March 27, 2017 i had a go at it i don't work with imperial system so it may be wrong also i used a landing in the stairs instead of a room as you had wall ontop of walls McVaugh.Jim Custom.zipFetching info... Link to comment Share on other sites More sharing options...
Designer100 Posted March 30, 2017 Author Share Posted March 30, 2017 Thank you mark that really helped. I still need to adjust the house finished floor to 66 in ht. later when i get back on project plans. Link to comment Share on other sites More sharing options...
