Terrain feature help
Dennis_Gavin
I am working on a plan for exterior presentation for another remodeler and am having trouble with the driveway relative to the terrain.
I cannot get the circular section to join with the lower section.  Can someone have a look?  Also drive is floating above terrain and changes
to it react badly elsewhere.  ;o(
https://www.dropbox.com/s/3gzr35jguqlseep/Combs.zip?dl=0
Thanks!
BTW,  I was almost going to compliment you on the terrain,  not bad,  however your garage does not have a room definition thus you have dirt in your garage.  You have a bad wall connection so your garage is a room and then you will not have dirt in your garage.
Pretty darn good model.
