Schedules and 2D symbols
Griffin
I thought not. Too bad though, both the 2D and 3D symbols for schedules are essentially useless as the schedule will fill a full page to have the text readable.  Converting the schedule to text strips out the symbols too.
Thanks Joe.
This post was helpful, from Tommy1
Mike,
It is usually the column width that determines the size of the images.
And it is usually a long column name that causes a wide column.
So, abbreviate the column name and then drag the column width narrower, the image sizes will shrink accordingly.
You could also have a play with the Scale Images setting, if that is causing a problem.
The attached pic shows two 2D Symbol columns.
The one on the left has been dragged narrower and the named changed to just "2D".
