Clemsongrad Posted February 10, 2017 Share Posted February 10, 2017 My friend wants a high window above their double entry doors in wall that has end wall trusses above. The truss manufacturer doesn't know how to achieve this. I put in a window which shows in the elevation, but does not cause the truss to rebuild. The rest of the trusses in the building apart from the end walls have sloped bottom chords. (You can see this in the attached pdf.) How do I get chief to frame this in order to get a window in the end wall? Thank You Larry dudley24x40 shell V2-Perspective Framing Overview Image.pdf South Elevation Image.pdf Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 10, 2017 Share Posted February 10, 2017 Post the plan and I'll show you how, but on a side note, are you sure you don't just want to balloon frame that wall? Link to comment Share on other sites More sharing options...
parkwest Posted February 10, 2017 Share Posted February 10, 2017 Why not eliminate the end truss and build a framed wall? You will have to do that anyways to insulate and finish the interior of the end wall. Link to comment Share on other sites More sharing options...
Clemsongrad Posted February 10, 2017 Author Share Posted February 10, 2017 I spoke with my friend and suggested a framed end wall. I also suggested keeping the scissor truss at the end and stick framing the rest. He will talk to his builder. Thanks Link to comment Share on other sites More sharing options...
Clemsongrad Posted February 10, 2017 Author Share Posted February 10, 2017 Here is the plan file. Thanks Larry dudley24x40 shell V2.zip Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 10, 2017 Share Posted February 10, 2017 On 2/10/2017 at 4:55 PM, Clemsongrad said: Here is the plan file. Thanks Larry dudley24x40 shell V2.zipFetching info... Expand Make sure to close the plan before trying to zip or post. Link to comment Share on other sites More sharing options...
Clemsongrad Posted February 10, 2017 Author Share Posted February 10, 2017 Forgot to do that again! dudley24x40 shell V2.plan Link to comment Share on other sites More sharing options...
parkwest Posted February 10, 2017 Share Posted February 10, 2017 Why do you need to post your plan on here? If the framers can't figure how to frame the gable wall, they shouldn't even be allowed on the jobsite. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 10, 2017 Share Posted February 10, 2017 Here you go Larry... 1 Link to comment Share on other sites More sharing options...
Clemsongrad Posted February 10, 2017 Author Share Posted February 10, 2017 Michael, Wow and thank you! The truss manufacturer had an end wall truss designated, and I put it in and then took it out. Now that I see how you did it, I can use your method and show them what we need using and end wall truss like your upper drawing. Parkwest was concerned about the builder, so I'll fill you both in. My friend is trying to be very frugal, so he found a company who builds shell buildings using trusses only. My friend is trying to get some customization done within their construction parameters so he is dealing with the truss company and the builder. I'm not sure he is going about it the best way, but he thinks he can keep the costs down this way. I've watched hours and hours of training videos, but being new, I couldn't have figured that out without your help! Thank you so very very much! Larry Link to comment Share on other sites More sharing options...
parkwest Posted February 10, 2017 Share Posted February 10, 2017 Larry, be sure to ask the brain trust you have there framing this truss house how they plan to insulate and drywall that vaulted ceiling area on that end truss. ;-) Do I need to make a video on how to frame a gable wall in a vaulted ceiling area? j/k Link to comment Share on other sites More sharing options...
