dssharp Posted February 9, 2017 Share Posted February 9, 2017 Why is there not a comments section in the room finish schedule? Also, why is there no option for volume envelope? Third, is when a ceiling plane (cathedral example) is created the schedule data says NA. Note ceiling over room has been unchecked in the dbx in that room. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 9, 2017 Share Posted February 9, 2017 Hopefully, there will be more in the Room Finish Schedule next week when the full X9 version is released. Link to comment Share on other sites More sharing options...
dssharp Posted February 9, 2017 Author Share Posted February 9, 2017 Cheif should be able to do air volume calcs for distributions and circulatory ect. Other programs can. WHY WHY WHY Arghh Frustrated again. Link to comment Share on other sites More sharing options...
GerryT Posted February 9, 2017 Share Posted February 9, 2017 FYI: Chief does do this. They supply a 'canned' macro that you can place in your label to indicate room volume %RoomVolume%. If you want the total of all conditioned rooms, for all floors, you can just sum them up or use another macro, If you have no interest in macros I'm sure Joe or someone here can also help with that? Link to comment Share on other sites More sharing options...
dssharp Posted February 9, 2017 Author Share Posted February 9, 2017 17 minutes ago, GerryT said: FYI: Chief does do this. They supply a 'canned' macro that you can place in your label to indicate room volume %RoomVolume%. If you want the total of all conditioned rooms, for all floors, you can just sum them up or use another macro, If you have no interest in macros I'm sure Joe or someone here can also help with that? We need a vid from one of the grand masters on this. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 9, 2017 Share Posted February 9, 2017 I'm holding off on the Videos until the final X9 release. Then I will do a couple that will show volumes with the total calculated for "Conditioned Space". I just want to make sure to take advantage of all the capabilities of X9. Link to comment Share on other sites More sharing options...
