LeeDrafter Posted February 3, 2017 Share Posted February 3, 2017 Hi All, I'm having a weird problem. On the attached plan, the garage door and the garage man door are set to dimensions to the inch (no fraction) on the floor plan. On the foundation plan, the concrete cutouts are not centered on the door they are for. Check out the garage doors on the attached plan in the foundation plan. Why are they 1/8" off on the foundation plan from the doors in the floor plan? How do I fix this? I am in X9, but the same thing happened only with this particular file in X8. thanks!! Lee LOT 30 SPRING CREEK, CUTLER.plan Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 3, 2017 Share Posted February 3, 2017 If the doors have been moved the foundation may need to be rebuilt. Link to comment Share on other sites More sharing options...
country Posted February 3, 2017 Share Posted February 3, 2017 Did you move the garage doors after you built the foundation? If so, all you have to do is pull the foundation wall over before the doorways and then reconnect. You do not have to rebuild the entire foundation. Link to comment Share on other sites More sharing options...
jscussel Posted February 3, 2017 Share Posted February 3, 2017 The left framed wall of garage doesn't line up with the foundation wall. Off by 1/8" Link to comment Share on other sites More sharing options...
LeeDrafter Posted February 3, 2017 Author Share Posted February 3, 2017 Thanks Jon!! Sure enough, that was the problem. I can't believe I spent so much time trying to figure that out and it was that easy ;). thanks again Link to comment Share on other sites More sharing options...
