dimmitry Posted January 26, 2017 Share Posted January 26, 2017 My walls remain unclosed after l build foundations is there any help using chief architect X8 Protodimmitry@gmail.com Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 26, 2017 Share Posted January 26, 2017 You should first read your "Users Guide" found under the "Help Menu" otherwise I do not understand your question but sounds like you are off proper procedure for developing a 3 D model. DJP 2 Link to comment Share on other sites More sharing options...
KirkClemons Posted January 26, 2017 Share Posted January 26, 2017 This can be caused by walls that are out of alignment, or walls that are at different angles.(e.g. the first-floor wall is .025° while the foundation wall is at 0°) Check the angles of the walls that are giving you trouble, and then check that they are aligned across floors. Link to comment Share on other sites More sharing options...
