Basement Foundation Wall (Pony Wall) Alignment
SNestor
Maybe a CA guru who designs in an area of the country where basements are common can give me some insight on how to construct a foundation wall that is a pony wall...and get this wall to align properly with the wood framed wall above.  I can move the wall manually...and eventually get it to line up...but it's very time consuming.  Especially for a complex house where some of the walls are 2x4 with stone or brick veneer...and others are 2x6 with stone or brick veneer.
There must be a simple method?  I've thought that I may not have the "main layer" defined correctly...but I've messed with that a bit and without success.
I've attached a simple plan that shows where the foundation is placed automatically.
Foundation Pony Wall.plan
