cooksbay Posted January 23, 2017 Share Posted January 23, 2017 Having a problem with wall types in a current plan. I have interior walls that are foundation walls but are framed walls with sheetrock both sides. When I look in 3D the walls show siding on one side. When I click on the wall and remove the siding in the wall dialog the siding is gone on the wall but it is also gone from the entire exterior. I thought I may have removed something from the Default settings but I haven't found anything. My question is how do you change the settings on one wall without changing anything else? I'm sure it's probably a simple fix but I'm stumped. Thanks for the help. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 23, 2017 Share Posted January 23, 2017 If you are making changes to a Wall Type Definition it will effect all the walls using that wall type. If you only want to change one wall make a copy of the wall type before editing. Link to comment Share on other sites More sharing options...
cooksbay Posted January 23, 2017 Author Share Posted January 23, 2017 Chopsaw Thanks for the response. That did the trick. Link to comment Share on other sites More sharing options...
