Joe_Carrick Posted January 23, 2017 Share Posted January 23, 2017 This is the list of my currently available macros at $10.00 each: Format_Number adds Ruby methods to automatically format numbers into the standard display for the type of plan (Imperial or Metric). This allows a value in inches to be displayed in feet-inches-fractions: 80.8725 --> 6'-8 7/8" (rounded to a specified fraction - in this case 1/8's) or a value in mm to be display in m 7650 --> 7.650 m (automatically displayed to 3 significant places) Living Areas Opening Labels w Header - sample output: X7: W04 - 3040 SH - (3) 2x6 Hdr X8: W04 - 3040 SH (3) 2x6 Hdr X8: W04 - 3040 SH Tempered Egress (3) 2x6 Hdr Note: In X8 if the opening is Tempered an/or Egress, those options will also be displayed in the Label Post Footing Labels - sample output: 24"x24"x12" FTG w/ (3) #4's e.w. 16" Dia x 12" FTG Note: This macro requires X8 to be used in a Label - but it can be used in a Text Box with Arrow in X7. The reinforcing depends on the size of the footing. Wall Label- sample output: Wall 1.01 Wall 1.02 Wall 1.03 Wall 1.04 ... Wall 2.08 Wall 2.09 Wall 2.10 Wall 2.11 .... The whole number is the Floor and the decimal number is the Wall #. The Project Browser Wall Details will have the same names as the Wall Labels.4 BlockName used with Leader Line Text to annotate CAD Blocks. This is very useful for annotation of CAD Details made up of Library Blocks. To change the annotation, simply rename the Block. This will change the annotation for all like Blocks in the Plan CounterTops - These are used to accumulate and display the Areas of Counter Tops %Counter Top Areas% is placed in the Label of Cabinets and Custom Countertops %Counter Top List% is placed in a Text Box %Counter Top Total Area% is placed in a Text Box Example output is: For Metric Plans the output is in mm rather than Imperial units. Chief Architect Version (Displays the Version of Chief Architect in use) Area_Perimeter_Volume (Displays those values for Polyline, PSolid & Solids) Vent Labels (Displays a 2 line Label for Vents) -provides a 2 line Label for Vents as follows: I. Line 1 a. The first letter of the "Component Code" (upper case) Attic..........A Foundation ....F Garage.........G b. Any preceeding characters specified in the Label Tab of the Schedule V- as an example c. The Schedule Number Examples: AV-01, AV-02, AV-03 FV-04, FV-05 GV-06, GV-07, GV-08, GV-09 II. Line 2 a. The size (width x height) b. @ <height above floor Example: 16x6 @12" Naturally, as with all my macros, if the plan is metric the appropriate units will be used. In addition, the following "Macro Packages" are available at the indicated prices: Site Area Analysis Package ($75.00) - uses object type and line weights to provide Site Area Analysis Building Area Analysis Package ($75.00) - comprehensive area analysis based on room names/types Roof Area Analysis Package ($25.00) - calculates and displays the areas of roof planes Project and Consultants Package ($35.00) http://screencast.com/t/EUwgvruMXz0H Wordwrap Package ($25.00) Framing Labels ($50.00) - labels all framing members on Framing Plans and Wall Details - updated to use the current layer set for Cross Sections. Openings ($35.00) Vents ($25.00) - includes labeling & area calculations for required vent areas Wall Labels ($35.00) - includes the above Wall Label for Plan View display and additional macros for Elevation/Section display and for a Wall Legend display. The following require Chief Version X8 because of reliance on the layer attribute: Areas - Polyline Area Analysis ($75.00) - Site Area Analysis using Polylines and Layer Names. This package is easily customized by simply naming the layers of the Polylines. Video of the EASIEST TO USE Site Area Analysis Package. The following require Chief Version X9 because of reliance on the floor & layer_set attributes: Stair Labels - Section & Stair Label - Total (25.00) - provides comprehensive labeling of Stairs and Landings example: Plan Name ($15.00) - Displays the Plan Name in a Text Box based on the Floor and the Layer Set in use. Layer Set Scale ($10.00) - Displays the Scale in a Text Box based on the Layer Set in use. Rooms ($35.00) - Extends the Areas - Polyline Area Analysis to include the use of Rooms - available March 1, 2017 LayerSet Opening Labels ($25.00) - Displays different Labels for Doors, Windows and Wall Niches depending on the Layer Set in use. Basically this provides for the Header Label to be displayed on Framing Plans while the regular Door or Window Label is displayed on other Plan Views. I will be adding videos to the above "Macro Packages" list during the coming weeks and months as time permits. Some of the packages will be updated to take advantage of new X9 features. Special customization of any of the above is charged at $25 per hour. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 23, 2017 Author Share Posted January 23, 2017 If you have questions or wish to purchase any of my macros - please send me a Private Message. I would like to keep comments in this thread to a minimum. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 1, 2017 Author Share Posted February 1, 2017 Here is the video of the Site Area Analysis macro package Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 10, 2017 Author Share Posted February 10, 2017 Here's some samples of the Stairs Macro Package Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 24, 2017 Author Share Posted May 24, 2017 I have modified the Framing Labels Package to recognize the current Layer Set. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 17, 2017 Author Share Posted October 17, 2017 One of the users reported a problem with the Counter Tops Package. Basically for a Custom Counter Top with a Sink or other hole, the net area was being reported rather than the gross area. I have fixed that and anyone who has this package can PM me with their email address and I will email the replacement. -Joe Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 25, 2018 Author Share Posted June 25, 2018 Added a new "Wall Labels" package to include labels for: Elevations Sections Plan Wall Legend Link to comment Share on other sites More sharing options...
rectordesign7 Posted April 19 Share Posted April 19 Joe, how can I purchase some of your packages? paul@rectordesigns.com Link to comment Share on other sites More sharing options...
Mike-MNDG Posted April 26 Share Posted April 26 Joe, I would also like to purchase your packages, do you have a list and price for all? mike@mikenovickdesigns.com CAX15 Link to comment Share on other sites More sharing options...
Cadwork22 Posted Wednesday at 06:15 PM Share Posted Wednesday at 06:15 PM ceiling height? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Wednesday at 09:48 PM Author Share Posted Wednesday at 09:48 PM 3 hours ago, Cadwork22 said: ceiling height? What Format? Ft, Ft-In, in, etc. Link to comment Share on other sites More sharing options...
Cadwork22 Posted Wednesday at 10:09 PM Share Posted Wednesday at 10:09 PM Nevermind, I found that there are drop down menus for different macros. Thanks. Link to comment Share on other sites More sharing options...
