Slated Wood Mantle Hood
brinkbart
This is a slanted mantle hood for above your favorite range or cooktop!
I have adjusted the bounding box to ignore the moldings so you can slide your wall cabinets right up to it with no problems.
I have broken it up into two pieces in cases where you want to use the valance part with your own cabinets on top.
It does not have molding attached to it, so I have also included a molding polyline that fits it perfectly. The molding will probably be messed up upon import, but you can just add your own crown to the polyline.
Stretch planes are set for slight adjustments in height and width. Probably wouldn't want to deviate too far from its original size.
Hope you enjoy!
slanted_mantle_hood.calibz
  • Upvote 2
  • 1 month later...
