X8 Camera Issues
mslewis620
Just starting to use X8 and quickly sketching a possible option for a client and when I went to full camera I am only getting a view of the garage slab and a vista - nothing else. Not sure what to check to resolve the issue.
Another odd problem is my room label text is almost invisible at 1/128" and shows up as custom text.
You can set your room label text size in Plan Defaults > Rooms > Room Label > Text Style.
You will need to check If the layers that you want to see have been selected in the Active Layer Display Options (ALDO).  It is likely using the Camera View Set but you can quickly switch it to the All on Set to see if there is some sort of a problem.
I am not sure then what might be going on here without guessing.  If you would care to post your plan file someone will be sure to check it for you and figure out what the issue is.  Just give a brief description of what you have drawn.
