JonathanJanacek Posted December 20, 2016 Share Posted December 20, 2016 So I just finished running Raytrace on an exterior of a house. I normally only run 10-15 passes for most of my pictures and notice the file size is never that big. So, just to see how "clear" the image could get, I set it to run for 500 passes. (yes, I let it run all weekend). I increased the size to 5000x2378 pixels and increased the DPI to 150. The file ended up at 1.31 mb. I'm not complaining that it's too big, but rather I expected it to be much larger. Is that a typical size for a "high resolution" Raytrace? Or am I missing something? I'd like to be able to raytrace an image that will look great when blown up to a 30"x24" picture. Thanks, Jonathan J. Link to comment Share on other sites More sharing options...
JonathanJanacek Posted December 20, 2016 Author Share Posted December 20, 2016 Also, what exactly am I gaining by going 500 passes? Or increasing the DPI? When you zoom in on the image, there is still a lot of pixelated areas. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted December 20, 2016 Share Posted December 20, 2016 The DPI setting just determines the print size in inches based upon the pixel width & height. Running 500 passes is not likely going to yield a significantly better Raytrace, I find that after about 30 passes the difference between it and say 100 passes is not often detectable. The last time I sent something out to a printer they wanted 600DPI resolution. Based on your 30" X 24" print size you need to change your width to 18,000 and the height to 14,400 and the DPI to 600. This could take a very long time to Raytrace, double the pixels quadruples the time. Graham Link to comment Share on other sites More sharing options...
