coloured lights in ray trace
gratepunkin
Here is some work that Rich did likely using the same technique as Warren.
https://chieftalk.chiefarchitect.com/topic/10348-false-ceiling-design/#comment-91269
You may have to experiment with an emissive material on the bar top.
Or try out this custom fixture and inset it into the Bar top and it may help you get started.  You may need to adjust the Attenuation depending on the other light sources.
Bar Top Light.calibz
