Exporting & Importing Autocad Files and Drawing Templates in Acad into Chief Layout Sheets
DCB123
Users of Chief;
I am trying to figure out a way to import my AutoCAD files into Chief importing only the Title Block information
so that I can export it into the layout sheets and set this up for the standard layouts that I will be using for this job from the architect
primarily? I need a step by step procedure here please; you can email me or call me, or text me with your replies.
I will eagerly await your replies.
Thx,
DCB
Accurate Asbuilts & Designs
Email: douglasburgmann@gmail.com
(970)987-4476 cell
1619-FINAL-TITLE.pdf
1621-161024-1-T.pdf
1. Start a new Plan and save it somewhere.
2. File>Import>Import Drawing (DWG, DXF...)
3. Step through the Import Drawing Assistant; when you get to the Select Layers tab uncheck everything except the title block layer.
4. Once the data is imported,  Copy it to your clipboard.
5. Open a new Layout and save it in the same directory as the Plan file.
6. Paste the contents of the clipboard into Page 0 of the Layout.
7. Move/scale/tweak the data to finish setting up the title block on Page 0.
8. Save your work.
