NewAsia Posted November 1, 2016 Share Posted November 1, 2016 Hello,I want to import 3ds Max model to Chief with Texture, I try many times with different file fomats ( obj, 3ds...) but it didn't work. Is there any way that I couldimport 3ds Max model to Chief with Texture?I attach 3ds Max model. Please check it.Thank you! Link to comment Share on other sites More sharing options...
johnny Posted November 1, 2016 Share Posted November 1, 2016 I dont see your attached file - however, 3ds should work. If you attach the file I can try on my system and see what happens. Link to comment Share on other sites More sharing options...
jcaffee Posted November 1, 2016 Share Posted November 1, 2016 I have never had a Max file work as Max textures are specific to that software. Link to comment Share on other sites More sharing options...
johnny Posted November 1, 2016 Share Posted November 1, 2016 You can setup a Max export so that it simplifies the textures to a point (its called "Baking") you can get a good export. The complexity of this process is determined largely on the model specifics. Chief is very basic when it comes to its ability to map textures. But, yes, you cannot simply export/import into Chief any .3ds file you want to include all the textures as they are in Max. Link to comment Share on other sites More sharing options...
abrandner Posted November 1, 2016 Share Posted November 1, 2016 The trick is to create a new material using your texture. If you bring in an .obj and then apply your material in chief it will work. Just make sure to have good UV's in max. Here is the link to creating a new material... https://www.chiefarchitect.com/support/article/KB-00767/creating-a-new-material.html Link to comment Share on other sites More sharing options...
